what turbo for my setup
Discussion in 'Forced Induction' started by wardatron, Nov 4, 2006.
  1. wardatron
    wardatron New Member
    UNITED KINGDOM
    im currently looking for a turbo for my B16A
    current set up is
    skunk2 valves,
    retainers,
    cam gears
    turbo race cams stage 2+
    STR fuel rail
    255 High pressure fuel pump
    precision 780cc injectors
    intercooler 24" 12" 4" inlet/outlet 3"
    81.5 pistons (low compressin)
    eagle h beam rods
    elderbrock victor x intake manifold
    STR 74mm throttle body
    4340 forged crankshaft
    fidanza 8lb flywheel
    3 inch down pipe ( 5 bolt )
    ss auto chrome 50mm turbo manifold
    block guard
    any suggestions i wont a 5 bolt turbo if possible
    also if i bolt my BOV to the manifold and leave esposed will i get the chatter noise ? or does something else have to be fitted from the BOV
    ( i no im a total noob ) just lil help will do fine
  2. ryan89crx
    ryan89crx Senior Member
    Washington State
    your BOV doesnt bolt to your manifold, your wastegate does....
    look through BLAAST PERFORMANCE - CUSTOM TURBO CHARGING, they sell quality rebuilds at a nice price. look at the compressor maps to find one that suits your needs.
    id suggest either a .48/.60 or .63/.60 57 trim, both will make excellent power with a nice pricetag
  3. wardatron
    UNITED KINGDOM
  4. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    dont buy there manifold plain and simple. do you want any bottom end? low compression big turbo b16's have no NO bottom at all, so think of that before you jump on a turbo.
  5. pissedoffsol
    and 5-bolt (ford-style) turbos are rare as hell, and no "good" turbos come in that shape flange. get a normal t3 4-bolt mani and downpipe setup, and you can run just about 90% of every turbo made
  6. ryan89crx
    Washington State
    how so? pretty much every .48 a/r turbo ive seen runs that flange. i agree if you are runnin a .63 or bigger, but ive seen lots of turbos with that exhaust side. my t3/t4 hybrid sitting on my desk shares the same flange as the Ford .48/.60 right next to it...
  7. pissedoffsol
    if you're running a 48 on a b16, there's other issues at hand....
  8. wardatron
    UNITED KINGDOM
    a 48 trim turbo u mean ?
  9. ryan89crx
    Washington State
  10. element
    element New Member
    dunno about being rare but my t3/t4 turbonetics with 48 ar has a 5 bolts batern
  11. wardatron
    UNITED KINGDOM
    im thinkin about the sc61
  12. ryan89crx
    Washington State
    thats a pretty damn big snail
    i suggest looking through various compressor maps and finding one that fits your goals. bigger is not always better, especially when it comes to spool times.
  13. wardatron
    UNITED KINGDOM
    what would you suggust im wantin to achieve around 400 whp
  14. gettocrx
    gettocrx Member
    Honolulu, HI
    I believe Westcoast turbo has rebuilt turbos for cheap. and you can select any turbine housing you want! Haven't bought anything from them but planning too in near future! For turbo size (400hp) I say t3 60-1 with a .63 ar turbine but in your case I believe that's a .48 a/r. Or maybe a t3/t04e to get boost a little sooner.
    check out their site!
    WestCoast-Turbo.com :: Garrett Turbos - T3 - Super60 - T3/T04B - T3/T04E - T3/60-1
  15. wardatron
    UNITED KINGDOM
    im swayed more over to a precision turbo
  16. arf4n
    arf4n New Member
    UK
    How you going to tune it mate?
  17. wardatron
    UNITED KINGDOM
    im going fully standalone but dont know on which manufacturer yet
  18. CoreyR
    CoreyR Senior Member
    just so you know ssauto 5 bolt turbo hosuings are different than real garret so that downpipe wont work on a REAL garrett/precision 5 bolt housing without cutting up the downpipe and re welding it.
    for a B16 an SC61 with an E cover and a .63 exhaust would be a good combo for 400whp.
  19. wardatron
    UNITED KINGDOM
    im prepared to re-weld just need a turbo and then play it from there
  20. spoolin@idle
    spoolin@idle D Series FTL
    Kansas City
    do NOT buy an ssauto turbo or any of the XS power ebay shit.
    there's no damn need to go "fully standalone" by means of a Haltech or something. If you are OBD2 and you decide you want more tuning capabilities, go with Emanage or AEM EMS.
