What Type Of Mtf Fluid Should I Use
Discussion in 'General Tech and Maintenance' started by boog, Feb 22, 2003.
  1. boog
    boog Junior Member
    Ok I did a search and can't get a good answer, so I am asking you guys. What type of manual transmission fluid should I use in my 99 civic si.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    OEM honda MTL fluid. Reason is because honda engineers specially formulate it for the conditons of honda parts
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Honda.
    I have used non Honda only once. That transmission is no longer with us...
  4. GSRCRXsi
    MD
    what is mtl fluid?
  5. asmallsol
    Manual transmission Lubricating (not sure what the L stands for) fluid
  6. cockstronghalfablocklong
    cockstronghalfablocklong Member
    Wilmington, DE
    so you can't use any aftermarket fluids, like redline or whatever?
  7. asmallsol
    some people swear by redline others say that it made their problems worse. I would go with what the engineers say. Use Honda MTL fluid.
  8. cockstronghalfablocklong
    Wilmington, DE
    what about additives? is there anything you can do to reduce hp loss through drivetrain? i thought the only way to do this with hondas was with fluid. i mean with a big block chevy you can put a lighter tranny behind it and not lose so much at the cost of durability.
  9. pissedoffsol
    no- the way to do that is to get a stronger holding clutch.
    honda MTF
  10. boog
    boog Junior Member
    ok I need to get some fluid today to put in the tranny. The dealership is closed. I can change it again tomorrow after I make that 30 mile drive to the dealership. O I did not say that I am doing a tranny swap (my si tranny is out already) so that's why I am in a hurry.
  11. asmallsol
    I would just wait for the one day and then have someone drive you up to the dealer.
  12. boog
    boog Junior Member
    Well I would do that but I need the car ready to drive tomorrow morning. I have been with out a car for 4 weeks(long storry). I just need something untill I can make it after about 60 miles of driving.
  13. GSRCRXsi
    MD
    is the fluid essential? this may sound like a dumb question but ive never changed the fluid. is this something like an oil change? do you have to change this fluit often? someon clear this up please.
  14. asmallsol
    you should change it every 30-40K miles but i have heard (at least with automatics) that if you never change it and then a 140K you change it, new leaks can develope and ginding can accor.
  15. GSRCRXsi
    MD
    ok i guess im going to be changing the fluid pretty soon then, i doubt the last owner did it ever. so teach me. is it just like changing the oil? is there a filter? how do i get the old fluid out? how and where do i put new fluid in? where do i get fluid? how much do i get? is the fluid specific to the engine/transmission? how much will the fluid cost? sorry for all the questions, but ive never done this before and although theres probably little chance of anyone fucking it up, my chances are high and id like to minimize this chance as much as possible. :lol: so if you could answer my questions, that would be great. thanks.
  16. asmallsol
    i am sure that the amount used is a little diffrent on diffrent trannys. For the fluid, go to a honda dealer or Hparts.com (discount OEM parts). Make sure that you put exactly the right amount of fluid in there, too much and you will blow stuff. On i think hybrid garage, they have insturtions on how to do it.
  17. SolReaver
    SolReaver Senior Member
    no, you cant put too much in cause the fill hole is the maximum level of fluid you can put in, otherwise it will spill out. It will just burn the excess off, not "blow stuff"
  18. asmallsol
    did not know that the fill line is also the maximum.
    About blowing stuff up, on transmissions (all companys not just honda) the main reason for blown transmissions is do to over filling them. This will cause seals to give and you will have more trouble then what you started with. Now alot of new models, the automatic transmissions dip stick is no longer on there because people will over fill them.
  19. civicSiR1
    civicSiR1 Senior Member
    I had ITR tranny.....poured in Redline MT fluid.......it knocked the socks off of me....that tranny meshed and cracked like sex and chinese new year...go with HONDA....
  20. cws13
    cws13 Senior Member
    Athens,GA
    Honda has a TSB about additives causing synchro damage. Do not use it. Also, ITR's call for a change every 15K. If you want to sell that B16 tranny, e-mail me.
