what type of suspension?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by DjMcPhatty, Nov 6, 2002.
  1. DjMcPhatty
    DjMcPhatty Senior Member
    St. Louis, MO / Huntsville, AL
    shit i wish i had the money for the teins, i just want something good enuff for right now. maybe someday in the future ill go with a true suspension set up, a full tein coilover set up, maybe
  2. CRX-YEM
    Wallingford, CT
    well for a descent price I think a set of neuspeed sport springs, matted with either kyb agx's or koni adj will suit ya just fine. springs are about $130 from alljdm.com. and the shocks are about $85-$120 ea.
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    then you're only 300 away from tein ss's :) i'd just save for those meng
  4. eyesonlybob
    eyesonlybob Senior Member
    ya i figured about 750 for a koni/eibach set up so i decided i will go tein. :p
  5. DjMcPhatty
    well, i thought teins were more expensive than that, how much would a whole set up cost me? If its only like 300 more ill just save and get the good shit.
  6. pissedoffsol
    SS's are the cheap model for teins... the ha's are 1500 with PBMounts and the N1's are 1700
  7. ZC 89HATCH
    ZC 89HATCH Senior Member
    nor cal
    word i should of got tein ss then
  8. eyesonlybob
    i thought i heard someone say that the ss's replace the ha's and that the pillowball mount isnt needed anyway.
  9. E_SolSi
    the pillow mount isnt "needed" but its a good thing to have ... it gives the top part of the coilover a much more stable/solid mount (steel or aluminum Vs. rubber) it will give more precise handling and better road feel (the ride will be somewhat rougher)
    and on some cars ( not hondas :( ) the pillow mounts allow camber adjustments
  10. eyesonlybob
    i may or maynot get one eventually but i will start out with the teins.
  11. B16
    yay area, CA
    the ss's are the same as the ha's minus the helper spring, the ss's are a direct replacment for the ha's.. so, they are not that "cheap".. still 16 way adjustable shock w/ride height adjustable spring..
