and just so you know im gona copy cat that motor build lol well almostBake me a pie...for my uh, Z6.
umm did you read what blanco saidwould it be worth throwing a DOHC head on it and if so what would do the job ????
because its about 5 inches wider and 3 longer than the block,,( note, not sure on the size but you get the point )yea but the head on his build was single cam i mean its a 16 valve head so why cant you throw dule over head on it ??? sry i just dont know
well i like the d16z6 but ive always liked the d15b,,and i have alot of stock d15b7 motors just sitting around so i may just put the z6 head on one of those and build it with the parts you have listed ,can that be done ? if i use the d15b7 motor will i need to change to a z6 crank ?,,but the only thing i was gona change was maybe different pistons, and a bigger camHmm. Well, a rough estimate on price would be $200 less. I spent $200 on OEM Honda bearings (I don't recommend ACL/Cleavite/King/etc., but some people like them) and around $400 on the rest of the stuff, including spark plug wires and water pump. I got this HondaAutomotiveParts.com. I figure that the plug wires cost $60 from Honda or around $30 from VatoZone. So, you'll probably save 50%.
Actual work hours or research hours? Work hours were probably around 10-12 and I'll say a conservative 300 research hours over about ten months. I take my sweet time when I'm working, since it's a hobby, along with having to take the block apart to get it decked and I had to have one of my rods swapped out after I'd already put the block completely together. The first problem could've been avoided had I checked the deck before assembling the block and the second one was the machine shop's fault. They either bent/twisted one of my rods or didn't bother telling me that of them wasn't true, either way I had to pull that piston/rod out to have the piston pressed onto a different rod. Thankfully I had one that had the same bearing size. At least I know the block was built well the final time.
So...where's my pie?
Right on. I've been thinking about getting a different cam, but then I'd also want to raise the compression for n/a. I'm thinking either Crower Stage 2, Skunk2 because their new lobe profile is supposed to make more power, or Bisimoto stage two. What else were you going to do different?
blanco is the man when it comes to the d series, if he says it do it.im going to
