not all swaps are just a direct pull the engine and it magically bolts up... most of them are pretty simple and easy but b series will require different axles and some other stuff that your d series equiped car does not have. also different year engines and harnesses will have a couple of different connectors and stop down harnesses may or may not be needed depending on what you decide to do here and there.
basically lots of little things can ruin your day if you did not know about them.
