What will happen if we used the wrong spark plug?
Discussion in 'General Tech and Maintenance' started by Ivan323, Apr 9, 2007.
  1. Ivan323
    Ivan323 New Member
    Hi guys, i brought the wrong NGK Iridium spark plug model for my Honda civic EK SiR B-series model.
    Will i damage the engine or cause any problems to it?
    After i had changed, i kinda smell some sort of buring smell inside my car.
    I'm quite worried is it the cause of wrong model of spark plug i brought?
    I brought ZFR6FIX-11 instead of BKR6E-N-11.. :(
  2. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    yes you can mess things up. i strongly suggest that you go and get the right plugs for your car... the thing is that the plug may be too long or too short, causing bad things to be happening.
  3. Ivan323
    Ivan323 New Member
    OMG!! :eek:
    I guess i got to buy another set of spark plug asap.
  4. CRX-YEM
    Wallingford, CT
    most likely the plugs aren't much different in size. The main differnce will be the heat/thermal rating. which results in a higher or loer tip temperature which is then related to detonation, pre-ignition etc... now if the length of the plug into the cylinder is in fact too large then yes there could be some big problems.
  5. turbo sol
    yeah... that's kinda where i was leading, but then the class bell rang and i had to send what i had typed up... figured it would answer his question:ph34r:
  6. Ivan323
    Ivan323 New Member
    Oh i see...
    Thanks for the explanation :)
    I'm really worried about the burnt smell after i removed the spark cable..! :eek:
  7. turbo sol
    next time when you know you got the wrong part, just go get the right one... it will save headaches.
  8. Ivan323
    Ivan323 New Member
    Yeah man..
    Thanks for the help.
    I already got myself the correct plug for my car today.. :)
  9. turbo sol
    cool... she should run better now.
    your car thanks you.
