What wires to ecu need to be ran?KNock?
slammedb18acivic
What wires need to be ran ? I currently have a 0bd1 p72 which may be running the motor for alittle bit. I am getting the p30 later. Also what needs to be ran for Knock sensor? and where is it located? My car is an ex so im already ran for vtec. Any help ?
IF YOU ALREADY HAD A VTEC YOU SHOULD HAVE A KNOCK SENSOR WIRE, THE SENSORS ON THE BACK OF YOUR BLOCK JUST ABOVE THE OIL FILTER IT SHOULD BE A BLUE/RED WIRE
