what wiring needs to be done?
solless
A couple of friends and I are going to be swapping a b16a into my 93 del sol non-vtec. The motor was originally in my civic DX but we're pulling it out of that and it's going into the sol.. So will we still have to do alot of wiring to get it running right in the del sol or is it basically already done from when it was swapped into the civic?? The swap also has a obd2 to obd1 conversion harness on it that will be taken off if that will have any effect on anything. Thanks
You'll still have to run your VTEC and knock sensor wiring from the shock tower plugs to the ecm.
