What would I need for a B16A swap in an 89' civic?
Discussion in 'HYBRID -> EG-EK / DC' started by hardweapon, Oct 7, 2002.
  1. hardweapon
    hardweapon Member
    I was wondering, I have a buddy (blackteg) has a B16A from his brothers car in his shop and I was thinking about dropping it into my car. I have a 89' Civic Dx 4-door. I really want a cheap swap and I would rather have a B16 than a ZC. Can any of you tell me what I would need for the swap into my car? Like motor mounts, ECU and stuff like that? And if you could roughly how much cost wise. TANX.
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    If you want a cheap swap, don't get the B16. Unless you consider 2000-2500 cheap. Are you doing the work yourself? That plays a big factor in cost. Anyways..
    Engine
    Tranny
    Mounts
    ECU
    Wiring Harness and Conversion Harness
    Custom Axles
    If ya do it yourself, I would guess maybe 1600-1900
    In a shop, closer to 1800-2500
  3. pissedoffsol
    well, if you are getting the motor for free-- you still need:
    mounts: $500
    ecu : 100-150 ish
    shift linkage: $200 ish from hasport
    plus misc shit like hoses and belts
  4. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    dont forget its a dx... bring on the wiring :)
  5. djextremity
    didn't even see he was putting an engine he already has in..=X
  6. hardweapon
    hardweapon Member
    So what do you recommend then that's cheap, besides a ZC? An H22 is gonna be worse than the B16 we don't even want to talk about an LS it's gonna be even more so what other options do I have?
  7. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    how will an LS be more?
  8. hardweapon
    hardweapon Member
    Well I have to have the proper mounts and shit and well I don't know isn't it? Like how much are we talking here?
  9. cxjon
    cxjon Senior Member
    man+k+toe
    about 1200 or so.....
  10. djextremity
    If cheap is a major part of the vocabulary, you should reconsider swapping engines. It's not a cheap process - cheap is the kind of thing that gets people hurt or disappointed. Cheap =/= thorough..
    Doing the work yourself:
    ZC: $800 130hp/108lb-ft
    D16:$800 125hp/106lb-ft
    B16:$1600-2000 158/112
    minime:$400 i dunno the specs, somewhere between d16z6 and d15b2 specs, i would imagine something like 120/103
  11. knowledge
    knowledge Senior Member
    Beale AFB, CA
    actually a mini me will yield a higher HP than the Z6 itself because of compression. Its usually around 130HP for a mini me swap!
  12. djextremity
    I didn't know it raised compression..well that's cool..learn something new every day =]
  13. Jeef
    Jeef NO MA'AM Moderator VIP
    Yeah but the z6 is more reliable. The mini-me is prone to overheating if it is not built properly. You can pick up a z6 for about 500 bucks.
