Whats A B-pipe Is?
Discussion in 'HYBRID -> EG-EK / DC' started by Civic98HB, Mar 22, 2003.
  1. Civic98HB
    Civic98HB Junior Member
    Well I heard if you do swap B18C1 in Civic 96-00 you will have to cut B-pipe in your exaust system.
    But were is that B-pipe
  2. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    i think you mean the d-pipe or the down pipe
  3. boostdGS
    boostdGS Member
    the mid pipe, or b-pipe is the pipe that connects your cat to your muffler.
  4. hcivic.com
    he is talking about cuting it for a swap so i would assume he means the down pipe
  5. boostdGS
    boostdGS Member
    no, because the header+cats' are different lengths
  6. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    i think you guys are actually talking about the same thing. i've heard it being refered to as a mid-pipe and a down pipe. On a GSR swap into a Civic, yes it's true that the header will not bolt right up to your car. I have seen different ways around this problem. You can either take your car to a muffler shop and have them extend your mid-pipe(the piping that connects the cat to the muffler) by about 2 inches or so, but i have also seen people extend out their cat. They will cut the part the flange is on and extend it out.
  7. boostdGS
    boostdGS Member
    you guys made me bust out my paint skills [​IMG]
  8. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    Nice illistration. I worked at a honda junk yard and the down pipe we called the a pipe and the mid pipe, is the b pipe. :ph34r:
