whats better pr4 integra ecu or stock 91 si ecu?
Discussion in 'HYBRID -> ED-EF / DA' started by jasonga30224, Mar 4, 2010.
  1. jasonga30224
    jasonga30224 New Member
    i need to know which ecu will be better for a d16a6 pr4 integra ecu or the stock 91 si ecu
  2. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
    PM6 (stock D16A6 ECU) the original ecu is always best!!
  3. BrutalB83
    Rochester Hills, MI
    If you're talking about a fairly stockish engine, then the ECU that goes with the motor is the best choice. If you're tuning or switching OBD or something like that, then you might use a different one, but if you just need to run a fairly stock engine correctly, then use the ECU that came with it from the factory...
  4. jasonga30224
    ok thanks for the help
  5. jasonga30224
    oh is the 90-93 integra injectors the same as the 88-91 si civic
  6. D16SiHatch
    D16SiHatch New Member
    90-91 teg injectors are the same, but 92-93 i believe would be saturated and don't need/use a resistor box..
  7. jasonga30224
    ok so the wire colors are the same?and is the resistor box on teg and civic si the same.
  8. D16SiHatch
    it might look different possibly, but they all perform the same function.
