I have three d series engines at my disposal. The 89 d16a6 in my crx, a 93-95 d16z6, and a 00 d16y8 (it needs to be rebuilt, hopefully the block and head are in good condition). What would be the best head/ block combo? I want to run higher comrpession, probably no higher than 12.5 I will probably end up running zc pistons and rods, but am open to other suggestions. This is going to be my daily driver, so it needs to be streetable. I would not like to touch the a6 motor unless it is the best block to start with, as I would like to do a direct swap to save down time, and build a panda motor out of it for futrue use. I am probably going to go with a mild street cam and aftermarket springs and valves if required. I am trying to stick on a budget. Any sugguestions?
