whats the best frankenstein setup
Discussion in 'Engine Building' started by frodriguez, Mar 18, 2010.
  1. frodriguez
    frodriguez New Member
    Ok, so i've been out for a while from my Honda game, and when I last left GSR was the best of the best. I recently got a 93 honda hatch vx. I like it and want to use this as my daily driver but at the same time, have a decent monster under the hood. Ok, sorry for boring u guys with my life story, but my question is what would be the best frankenstein setup to produce torque and power and at the same time be reliable? Along with this setup i plan on supercharging. Am open to suggestions.
  2. ricksautomotive
    ricksautomotive honda dealer tech
    lancaster, ca
    i would do either a v-6 accord set up or a S-2000 set up and with the rear wheel drive. i havent seen one of those yet. i dont know how much you can spend though. or you can do another engine mod like most people do but everyone has already done that pretty much
  3. Matts96HB
    Matts96HB . Moderator VIP
    a b20 VTEC is one of the most solid powerplants you can produce out of a b-series engine. loads of displacement paired with the proper breathing head and you have yourself a monster.
    the only problem is that the b20 bottom end will need some attention before being able to satisfy the VTEC head's rev happy powerband.
    the stock rod bolts on the b20 are known to be prone to failure. replace those with some arp bolts, get the bottom end balanced, and you're good to go.
    the other option here is an H22 swap, which will put you at about 200 crank hp and 161 lb ft of tq. the h22 swap, though more tricky than a b-series swap, is well worth it IMO.
    companies like hasport and avid have made it easy to do the h swap into the civic chassis. you could also go H2B which is an H engine with a b series tranny.
    i would stay away from anything other than these two swaps, especially if youre just getting back into it.
    k swaps are just far too expensive.
    j swaps are fairly inexpensive but have an ugly ass result. no hoods have been made to clear the intake manifold yet.
    anything RWD is going to have to be 100% custom fab work and is going to be way more costly than is worth it.
  4. Honda 94 guy
    Honda 94 guy New Member
    Matts96hb i have a 94 civic and wanna swap the engine but not looking for a racer jus something with a lil more speed. What would u recommend thats not to expensive also will nedd to change tranny as it has original and is going out. Any help would be great thanks.
  5. E_SolSi
    Hi, welcome to the site
    first, please start your own new thread when asking a question
    this thread is 7 years old
    but to answer you for now, a B16 or B18 swap is fairly simple and will get you a decent upgrade in power along with nearly unlimited options going forward
    how much do you have to spend
    what is your overall plan/goal for this car
    can you do the work yourself
    dilbeckskate likes this.
  6. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    make a thread for your car here with/pics and info (link below), Welcome To Hondaswap! http://hondaswap.com/forums/civic-and-del-sol-eg-and-ek.53/
