Whats the difference?
Discussion in 'HYBRID -> EG-EK / DC' started by ASIMO, Oct 26, 2002.
  1. ASIMO
    ASIMO Junior Member
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Only post one topic in more than one forum
  3. SnailOnARampage
    SnailOnARampage Senior Member
    Utah
    the differences between the two are this:
    Type S has an LSD
    Type S has a slightly higher rpm power peak, which gives it about 5 more horsepower
  4. SnailOnARampage
    Utah
    if i just gave any misinformation there....someone please correct me. preludes are not my specialty.
  5. ASIMO
    ASIMO Junior Member
    Well, the stats show an extra 20 HP in the Type S
    And sorry for posting in different forums but I posted in the other forum before I saw this one.
  6. SnailOnARampage
    Utah
  7. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    The Type S also has more aggressive cams and a higher compression ratio (11.1:1).
  8. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I am not sure about this, but I don't think that the American Type S has an LSD. It has a system called ATTS or Active Torque Transfer System that works something like an LSD, but it is not an LSD.
  9. dohcvtec_accord
    The left lane
    Yeah, don't get confused. The Type S is very different from the SH. The Type S only came in Japan, has a real-life LSD, more aggressive cams, a higher compression and a red valve cover.
    The SH came only in the states, and the only difference between it and the base Prelude is the above-mentioned ATTS, which is heavy LSD-lookalike which doesn't quite match up to a typical LSD in terms of functionality.
