what's the highest compression i can run on 91 octane???
Discussion in 'Engine Building' started by jspeccrx91, Jan 9, 2009.
  1. jspeccrx91
    jspeccrx91 New Member
    Kingman, AZ
    I got a b20 vtec i'm working on but all i can get around here for gas is 91. gonna keep this one all motor but need to know the highest comp i can go. also my b16 setup now makes peak power at 9200. i plan on using this head so what can the b20 safely rev up too? or what can i do to it to keep it together up there?
  2. efhondakid
    Akron-Canton, Ohio
    I wouldnt spin it past 6500, the stock redline for the B20s, any higher and youll slowly stretch the rod bolts, and eventually destroy the motor. This is only for a stock bottom end though.
  3. nootrac22
    exeter pa
    are you serious, 9200RPM?????????????:bs:
  4. jspeccrx91
    Kingman, AZ
    dyno proven, fully built head, port/polish, brian cower stage 2 cams
  5. 95b16coupe
    95b16coupe New Member
    ct
    can you post the dyno sheet?
  6. jspeccrx91
    Kingman, AZ
    be happy to post it up later 182whp b16
  7. efhondakid
    Akron-Canton, Ohio
    After you google a dyno sheet of something that makes power until 9200rpms.
  8. whiterabbit06
    Crestview, Fl
    I would have him write his username on the sheet then scan/take a pic.
  9. jspeccrx91
    Kingman, AZ
    dont have a scanner but my digi cam takes good pics not home right now or i would have it up
  10. austin20110
    austin20110 New Member
    Northern Va
    look forward to seeing it
  11. Magana559
    Magana559 The Warden
    fresno Ca
    I Would Also Like To See That Dyno Sheet.
    Im Going to Run A 12:5:1 CR And BC Stage 3 Cams On Cali 91 pump gas.
  12. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  13. NWDRVRBWE
    NWDRVRBWE Hands Off my Balls
    kentucky
    Wait... what?
    9200?
  14. whiterabbit06
    Crestview, Fl
    I bet you he had it on the dyno and reved it till it blew and the dyno sheet has a powerband that spans till 9200 rpm at which time he shut it off because he heard a lot of noise. He then decided to make another run and it blew up which is why he now wants to rebuild the motor. If by some miracle chance he is telling the truth and he does have an engine that makes peak power at 9200 rpm then he should know how his engine was built and have some kind of research on how to get it to make power at that range including the amount of compression. This leads me to believe that his claim is either a croc or he has extremely low compression and some really good quality parts.
  15. nootrac22
    exeter pa
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ALL ROTO NO MOTOR!!!
    bullshit your motor makes pa powr at 9200,thats when my boys fully built b18c5 drops off,and hes making a hell of alot mor power than 182whp
  17. jspeccrx91
    Kingman, AZ
    my bad i worded that wrong, after looking at my dyno sheet i peak around 8k drop off is 92. sorry for the confusion. no one awnsered my b20 question what can i do to safely rev to 8500-9k
  18. NWDRVRBWE
    kentucky
    for a simple answer, reving to 9k is just not a good idea. if you can do it or want to do it, go for it, but let me know how long your engine lasts...
  19. Magana559
    fresno Ca
    stay at 11:1 cr and only rev to 8k with stock rods and injectors.....it will still go soon lol
  20. phyregod
    phyregod !!YTINASNI
    Central Texas
    Alot depends on the motor.. Timing, chamber shape, material, surface, etc..
    My bike has 12.2:1 compression, runs great on 91. Try that with a 72 ford and it'll knock and ping itself into oblivion.
