whats the highestly you can safely boost a GSR?
Hey guys,
I was wondering whats the highest you can safely boost on a stock GSR engine, with a little fuel management?
0 psi.
You need good fuel management like an FMU (shitty), a VAFC (not ideal), or hondata (ideal) and larger injectors to run any boost safely.
The components will probably hold about 8-12psi, thats sort of the general consensis, but the HP goal means a lot more than PSI.
consensus seems to be 300whp among the DIY crowd.
Most ppl need 9-14psi to get there, depending on turbo size and efficiency, intercooler size and efficiency and competence of tuner.
Power is a much better measure of stress on the motor than boost level. Read in the forced induction forum if you need to understand why.
psi/boost is relative and in and of itself meaningless.
stock gsr blocks can hold 300 whp with PROPER fuel management
and 200-230 with hack jobs things liek fmus and vafc hacks
without anything, it will hold about 1 psi and make 160 whp. the map sensor with throw a check engine light at 2 psi and retard your timing into oblivion, and you'll make 40 hp.
way to cheap out
