hondamidnighter
As i posted earlier on about a Teo4h turbo my friend put on his del sol leaking oil, well its about that setup. But let me start first how he got the idea of ghetto turbochargin his del sol.
It all started with his friend saying that he had installed turbo in about 4 different cars and had been success and shit. Well he brainwashed my friend and started telling him things what to buy. He had a Teo4h turbo already lying around so he used that because even tho the wastegate was set a 5.5 he cant go beyond 6psi on a fmu setup. Then a 12:1 vortech fmu, eclipse intercooler(modded to fmic), flexible ghetto charge pipes, flexible exhaust downpipe, hose lines, check valves, and miscelleneous crap ect. So okay the way the guy installed the turbo was buy using the flexible pipe off the cat from the exhaust manifold and into the turbo.
After that he ran flexible pipe out of the compressor housing and into the intercooler which is a 2" pipe. Which I think is too big for the pressure too build.
Well as ive seen he ran everything okay as far as ive seen other setups. Had a few problems with the oil line but got fixed and no more oil leaked.
But here is the problem, my friend and his "friend" are pissed because the blow off valve is not loud until past 4000 rpm. They said that its probably the boost is not building up. So they ran without the wastgate opening and still didn't get high boost. They checked for leaks and didnt find any. The turbo spools and everything but well Teo4h turbos aint are really good neither. We thought it was the exhaust but he has a 2.5 cat.
What i think is that he shouldnt run his turbo like on the example on top. Or his charge pipes are to big for 5.5. But how can the turbo not make more psi even with the wastegate not opening?? <_<
