What's wrong with this?
Discussion in 'Members' Lounge' started by xj0hnx, Apr 8, 2004.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Linky
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    aren;t b16 rods a lot shorter than B20?
    or are the B16 pistons a smaller diameter?
    something has to make the .4 liter diffrence
    and i thought you can't stack headgaskets?
    ahhhhh, shorter rods = lower compression = motor built for turbo
    and wow, everything is teh GENUINE JDM HONDA
    thats greaaatttttt
    lol
    vvvv :worthy:
  3. xj0hnx
    C.C.TX.
    B16A 81mm bore
    B20B/Z 84mm bore
  4. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    :werd:
    b16 rods/pistons won't work in a b20 bottom end. b20 rod length is 137mm and the b16 rod length is 134mm (except for the b16b, I think it's a little different). btw, isn't the bore size of a b20, 84.5mm?
    oh and stacking head gaskets is ok, just don't reuse your old one, replace it with a new head gasket.
  5. Hatchbacks Anonymous
    Hatchbacks Anonymous Senior Member
    Anonymous
    Looks = :thumbsup:
    Motor = Risky. I would not buy a car from ebay, with an engine swap, with things that look "fishy" if I couldnt even drive it first.
    I know a guy that bought a B20z/VTEC for his car. The shit never ran right, and the motor was a POS. Supposed to be a great motor with new valvetrain, and rebuilt block.....yeah right. POS.
    Would I buy it? :no:
  6. phunky.buddha
    Dallas / Fort Worth, TX
    Sure you could use the B16 rods and pistons in the B20... you would just have zero compression.
    :lmao:
  7. driverunknown
    driverunknown Senior Member
  8. E_SolSi
    well lower compression is better for boost :)
  9. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Is that piston slap I here?
  10. xj0hnx
    C.C.TX.
    Hell ya, he could run 9,000,000,000 psi yO!!!
    I keep thinking about him starting the motor to show someone he is selling it to and hearing the pistons just flopping around, hahaha.
