whch tranny? 96-97 itr or 98+ itr?
Discussion in 'HYBRID -> EG-EK / DC' started by 96IntegGSR, Mar 24, 2004.
  1. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    I need to decide which tranny to pair with my b18c itr motor. should i get the 96-97 itr or the 98+itr? what's the difference/benefit?
    thanks
    jon
  2. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    oh, by the way, i have both trannys so if parts are better in one and a combination of the two is best, let me know. i really appreciate it.
    jon
  3. xkwzt21
    xkwzt21 Member
    the only difference is that the '96 ITR has a 4.40 final drive, and the '98+ has a 4.75 final drive
  4. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    4.75 accelerates faster, but the 4.40 is more tolerable on freeways.
  6. xkwzt21
    xkwzt21 Member
    the '98+ tranny will allow you to accelerate quicker...with the gear ratios being shorter...it will also eat more gas for a regular daily driver...but this tranny would be better for the tracks.
    the '96 tranny is more daily driver friendly...but it will not accelerate as quickly. I have seen a video where both a '96 and '98 ITR race and their quarter mile times were the same, eventhough the '98ITR accelerates quicker, the longer 4th gear in the '96 helped it to catch up.
    So, its your choice.
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    go wiyh yhe 98+
  8. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    what if i put the 98 final drive on the 96 tranny?
  9. E_SolSi
    ummmm then it would be the same as the 98
    if the ony difference is the final drive, and you switch it, then they arent different any more
  10. xkwzt21
    xkwzt21 Member
    if your gonna do that, get the '98
  11. 96IntegGSR
    96IntegGSR Member
    San Diego, CA
    well, i already had the 98+ tranny. now getting an engine tranny combo (cheaper that way) got the 96-96 jdm engine (500 cheaper then 98+) but the tranny i think might be in better shape. so i was thinking of putting the final drive gear from the 98 tranny i already have into the 96-97 i am getting. make sense? let me know if that sounds right.
  12. JDMilan
    Boca Raton, FL
    I would part out the motor that you already have...
  13. jwn7
    jwn7 Member
    university of pittsburgh, pa
    wait a minute... :unsure:
    i'm pretty sure (not 100%) that all usdm itr trannies are the same, with the 4.4 final. all 97 and below jdm itr trannies are the same as the usdm ones. the 98+ jdm itr tranny has the 4.785 final AND longer 4th and 5th gears. is that correct? i think it is.
    EDIT:
    it says so right here: http://www.hondaswap.com/forums/index.php?showtopic=29796
