wheel and tire size
Discussion in 'Wheels / Suspension / Tires / Brakes' started by webink_EK9, Jun 9, 2004.
Thread Status:
Not open for further replies.
  1. webink_EK9
    webink_EK9 Senior Member
    Whats the widest size tire you can fit and/or buy for a 15" x 6.5"
    wheel?
  2. UDT
    UDT Senior Member
    california
    Im pretty sure you can put a 205 on there............ anyone know for sure?
  3. webink_EK9
    You think 215's are too wide?
  4. pissedoffsol
    id throw a 195 on a 6.5" wheel.
    you CAN fit 225's on there if you really wanted to, but whats the point. your performance will be half what it shoudl be.
    your tires will have the baloon effect, and will have a lot of flex and handel like shit.
    6.5 = 195
    7 = 205
    7.5 = 215
    8 = 225
    and so on. thats my opinion anyway.
  5. webink_EK9
    so don't even do a 205 on that size rim? alrighty I'll shop for 195's I guess.
  6. pissedoffsol
    yoyu can and they will fit fine... but you are going to suffer more wobble than you would with the 195
  7. webink_EK9
    I'm getting a set of 15x6.5 rotas for backup autoX wheels. The tires are going to be hoosier's. Not going to be streeting these at all. I'm going to have 2 sets of slicks and one set of treaded autox tires for rain. The rotas are the group n 15's. Will this be bad for autox?
  8. pissedoffsol
    you'll notice it even more so in race conditions.
    think about it..
    skylines come with 18x10s and a 255
    most ex civics come with a 14x6 and 185
    most non-M bmw's come with 16x7 and a 205
    it makes sense.
    205 millimeters = 8.07086614 inches
    so as it is, putting a 205 on a 7" rim is already a 1/2 inch wider on either side.
    putting it on a 6.5, and you are in 3/4" wider on each side.
    225s, at almost 9" wide on a 6.5" wide wheel is just outright sloppy.
    if you want to go a step further- made tite dorifito jdm folks run stupid wide wheels with "thin" tires.
    its not uncommon for 18x10's running 225's. it gives the tire more 'stretch' and is thus tighter on the wheel
  9. phunky.buddha
    Dallas / Fort Worth, TX
    The bead is narrower than the section width of the tire- more so when you go to taller profiles. A 7 inch wheel is just about perfect for a 205/50/15 tire. I've got my 205/50s squeezed onto 15x6 GSR wheels, and you can see the sidewall leaning in just a tad- ideally, you'd like the sidewall to be vertical.
  10. E_SolSi
    :yes:
    you want this |____|
    not this /____\
    or this \____/
  11. webink_EK9
    Great info! Thanks a lot for the advice.
    Do you guys remember those wheels that stick out from the fender? Like really wide small wheels with 3 or so inches of wheel/tire sticking out. I've seen a few cars running those at autox, but I don't know where to look for them.
    I'm just trying to find the widest tire/wheel combo I can get and still turn the civic.
  12. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    if you are talking about tires sticking out past the fender, they probably have some type of spacer or lug extenders. you can buy them and what it does will make your tires/wheels stick out farther. they have different sizes. i guess it would give you a better center of gravity, idk.
  13. Crx Kid22
    Crx Kid22 New Member
    boring, oregon
    ohhhhh for my civic i run 205/50/15 wheels this is max without rubbing
  14. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    this thread is 5 years old guys, try looking at the thread dates
  15. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    I know I double posted but please tell me I wasnt THIS bad as a noob... F'N Fast and Furious... Influx of fackin terrible noobs
  16. phunky.buddha
Thread Status:
