Originally posted by B16@Jan 28 2004, 07:18 PM
if its around 60mph check wheel balance.
bearing you check for play by placing your hands at the top and bottom of the wheel and push with top, pull with bottom, alternate, check for play.
for tie rod ends, do the same, but place hands on the sides (horizontal, instead of vertical) and check for play in the same fasion.
