wheel hop? help
Discussion in 'Civic and del Sol - EG and EK' started by rkwoos12, Apr 19, 2009.
  1. rkwoos12
    rkwoos12 New Member
    Kentucky
    hey guys can any tell me how i can stop wheel hop in my 94 honda civic ex its a 5 speed and when i do 4k clutch dumps its starts spinning tires and i get a little bit of wheel hop, i use to get some major wheel hop before i fix three motor mounts in my car i fill up the diver side upper motor mount and the two lower torque mounts with the 3m window weld because they were half broke and i didnt want to replace them with new motor mounts. so if anyone knows how i can stop this wheel hop pleast let me know. thanks
  2. Briansol
    - limited slip diff
    - traction bars
    - better tires
    - learn to launch :)
  3. Korax
    Korax New Member
    Western PA
    ^ As well as probably getting those new motor mounts.
  4. eg6sir
    i know i had real bad wheel hop when i was running my cheapo coilovers and blown stock shocks on my EG (its how i bought it)..
  5. Magana559
    Magana559 The Warden
    fresno Ca
    what size rims/wheels do you have?
  6. rkwoos12
    rkwoos12 New Member
    Kentucky
    um i have 17inch rims came with the car and new tires there blue streek tires bit cheaper than those high performance tires but they do the job, as for the suspension its bone stock, and can you even get a limited slip diff for a d series tranny?
  7. rkwoos12
    rkwoos12 New Member
    Kentucky
    any tips on launching by the way?
    lmao one of my freinds tells me you can when your drag racing your suppost to double clutch. i dont under stand how you could possibly double clutch while drag racing if im wrong will some one please tell me how to do this. i know you can double clutch down shift but i think it would be point less to double clutch while your racing.
  8. awptickes
    MD
    Launch at your peak torque point, not the peak HP point.
    Get stickier tires, get smaller wheels for your 100 HP monster honda.
    Your problem is traction. Fix the driver first, then fix the traction.
    2 people like this.
  9. cvc_98
    cvc_98 New Member
    haha thats one crazy answer haha ......good luck on the wheel hop
  10. Ethan
    Ethan Well-Known Member
    lmao +1
  11. Magana559
    fresno Ca
    The problem is your 17's
    I Destroyed two trannys and a pair of axles when I had 17s on my boosted teg.
    1 person likes this.
  12. get_nick
    Washington State
    17's aren't drag wheels.
    watch what pro racers do, then learn from them.
    suspension, tires, wheels, etc.
    and no, double clutching isn't going to help. he was giving you the fast and furious speech.
  13. Pvtjoker122
    Pvtjoker122 New Member
    San Diego, CA
    lmao
  14. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    I say shocks because I had a lot of wheel hop when I first put my LS in (2nd gear too) and I put KYB shocks in (stock shocks were way shot). Wheel hop reduced.
  15. rkwoos12
    rkwoos12 New Member
    Kentucky
    right that is where my friend got that double clutching b.s. from lol i tryed to tell him.
  16. rkwoos12
    rkwoos12 New Member
    Kentucky
    peak torque poing? what would that be? and whats a good size rim best for spinning the tires. lol
  17. rkwoos12
    rkwoos12 New Member
    Kentucky
    im good at building cars but racing them i have to work on my plans are to swap out that d16 engine and go for either a b16 fully built with lsd tranny or ill go with a b18 with lsd tranny then later for turbo. but i appriciate all the help and feed back you guys are giving me.
  18. awptickes
    MD
    Code:
    johnny helped his uncle jack off the horse
    Johnny helped his Uncle, Jack, off the horse.
    You need to use some proper capitalization and punctuation. As demonstrated above, in a humorous manner, the meaning changes completely.
  19. awptickes
    MD
    Also, you'll probably need to replace the clutch soon. I'll bet what you're experiencing isn't wheel hop, but clutch/flywheel failure, induced by rampant ass-hattery. The d-series clutch and flywheel are well built, but not to the level that they like burnouts.
    Make sure all your engine mounts are still alright, and everything else is O.K. as well.
    Here's some reading material:
    Slipping
    EDIT: By doing burnouts, you not only do damage to your tires, but your clutch, flywheel, and possibly everything else in your stock 15 year old car. Please inspect/replace things before you do stupid stuff, and keep all stupid stuff on a track or skid-pad where it belongs.
  20. efhondakid
    Akron-Canton, Ohio
    Big wheels, stock mounts and suspension are the biggest problem, then learn how to load the clutch.
