wheel off set. ?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by 97hatch, Apr 16, 2006.
  1. 97hatch
    97hatch ?
    Anderson IN
    ok im going to get a set of steel 13x8s or 10s to put some slicks on what off set should i get 1-2-3or4 inch offset i want to get these ordered so i can get to racing any help is good
  2. GSRCRXsi
    MD
    offset is in inches? wtf? and only whole inches? ive only seen offsets measured in mm.
    1" = 25.4mm
    2" = 50.8mm
    3" = 76.2mm
    4" = 101.6mm
    if they are measured the same as offsets usually are, then the 1" seems to be the only one that will fit. more info on the wheels?
  3. 97hatch
    97hatch ?
    Anderson IN
    they are aero race wheels they are circle track midget wheels the bolt patern for them is 4x100. i can get them for $33 each in chrome black or silver.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    You'd probably want to get the 2" offset then, and clearance your fenders a bit with a baseball bat (rolling).
  5. GSRCRXsi
    MD
    id think a 8" wheel with 50mm off set would rub the inside...
  6. pissedoffsol
    yeah, you don't want to run circle track wheels dude....
    clayton knows a site where you can get custom wheels made dirt cheap for race app's. send him a PM (AirJ0ckey)
  7. 97hatch
    97hatch ?
    Anderson IN
    sweet ill pm him thanks b
  8. pissedoffsol
    i would have posted it but i forgot what it was called...
