Wheels angled
Discussion in 'Wheels / Suspension / Tires / Brakes' started by marek, Apr 20, 2005.
  1. marek
    marek Junior Member
    So today i got my car lowered on tein s techs, and the front wheels sort of angle in, is this normal?
  2. jangevines92teg
    jangevines92teg Member
    your camber is off.. it will make u wear tires more... id sugest a camber kit....usless its only angles a lil bit then it wont make much of a difference
  3. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    How much of a drop? Under 2" you should be able to just go to an alignment place and get them to fix it, beyond 2" your prolly gunna need a camber kit. Eitherway, take it to a shop and get it aligned when your all done, they have the technology to do it riiiiiight.
    Edit:
    Not only will they wear poorly, but they will become sawtoothed and loud after a few thousand miles.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Bah, get an alignment to make sure the toe is right, and call it a day. Camber wear is so '95. That is of course unless you have ridiculous camber from a ridiculous drop.
  5. pissedoffsol
  6. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    :withstupid:
  7. E_SolSi
