When do u shift?
Discussion in 'Civic and CRX - EF' started by hope801, Jun 1, 2008.
  1. hope801
    hope801 Active Member
    ok. i have a 91 crx hf chassis, hf tranny, and 91 si motor.
    my questions are:
    when would u suggest to shift, to save gas?
    When do u shift? (ur motor, tranny)
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    3,000 rpm, every gear.
  3. eg6sir
    x2.. thats what i told my GF to do in her GSR..
  4. LS_VTEC
    NJ
  5. BrutalB83
    Rochester Hills, MI
    The faster your motor is spinning the more gas it's going to use. For normal everyday driving in a Honda 3,000 - 4,000 RPMs sounds about right...
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    gas saving,shift around 3...
    racing i like to bounce it off the rev limiter a couple times before shifting:D
  7. eg6sir
    just so you know, that slows you down..
    anyways.. wanna save gas? dont drive, haha..
    just stay off the pedal and shift around 3-3.5k rpm
  8. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    When I had my Accord; 3200-3500rpm, with my Civic; 4000rpm, my brother's Civic(CX); 4300-4500rpm.
    I just pretty much keep the accelerator steady and shift when it feels like power is falling off. Hell, my Civic does ~70mph at 4000rpm anyways(yes, in 5th gear) :D
  9. 99sidude
    Ohio
    2500-3000 around town here, tho I'm stuck at 3500-4k on the highway.
  10. hope801
    k if i were to constantly be at
    35mph
    or
    50mph
    what rpm would u guys recommend to be at?
  11. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    As low as possible. Doing 60km/h (35mph approx) im doing 2000 in fifth, i do have a J1 tranny so its tough to keep the rpms low but its decent. Depending on the movement of traffic i normally shift at 2,500 to 3000.
    Alot of it depends on torque, more torque, less rpm needed to move, but usually the engine is larger so gas usage it more. Its a bunch of factors.
  12. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    :werd: :withstupid:
  13. |Chaz|
    |Chaz| Well-Known Member VIP
    Doesn't it use more gas though if you lug it?
  14. K2e2vin
    Raleigh, NC
    From my experience, pushing the accelerator down to keep speed uses more gas than just letting it rev with barely pressing the accelerator at all.
  15. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    I'd like to critique that first statement.
    I think in very general terms, you are correct, the faster the motor spins, the more gas is going to go through the cylinders.
    But, since we're EFI, not just some dumb carb, part throttle is going to be greatly improved. I'm thinking that drag, gear ratio, gravity, etc will all affect this, but possibly cruzing at one steady speed at a particular rpm higher than 'normal' could use less gas. The rotational mass of the motor's parts increase with speed. Thus, load on the engine is marginally reduced. And the ECU can make adjustments to the A/F, possibly making the higher rpm more efficient.
    For instance; I've noticed I use less gas going 90mph (approx 5k rpm in 5th) than going 80mph (approx 4.4k rpm in 5th). Very marginally so, but it adds up.
    Or if your still unclear on my concept, think back to when you've ridden a bicycle. It takes more effort to travel the same distance pedaling slowly compared to pedaling more quickly. It is more efficient to ride fast, to a certain degree (depending on wind, powerband [human powerband], etc).
    Input on my theory? I know there will be. Constructive criticism please.
    [@ OP's original Q] I've got a JDM B16A SiR-II with Y21 trans (w/ lsd) and daily town driving I normally shift at about 3,500~4,000rpm. I'd say average of 3,800rpm. Accel to highway like a normal human and not racing I'd probably shift at like 4,800rpm light throttle so you don't pop vtec for no reason (throttle pressure affects vtec crossover). Deffinatly, atleast with my current stock tune, vtec owns my gas. If I WOT just 1 gear, maybe it's just me but I can see that the gas needle drops rather quick. I probably have some issue of my own.
    I just wanna say, hitting the rev limiter is bad. That's only there if you miss shift. It's not a shift light. You might already know this OP, but I gotta say it, at least for Injen's sake ^_^
  16. YBLEGAL
    NW Indiana
    deffinatly
    deffinatly. no torque down low. dont shift under 3k if you plan on reaching 30mph or above.
  17. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i shift one of my cars at 3k every gear and im in 6th gear by the time i get a 8th mile away lol,
  18. LS_VTEC
    NJ
    Bouncing off the rev limiter? Holy sheep shit. When you hit the rev limiter, do you know what is actually happening Injen? Fuel cut/Spark cut. Fuel + Spark Cut = Bad news. Thats why we have two step :) Holds the RPM wherever you desire, and keeps fuel + spark to the engine. Wonderful for those 6500 rpm launches. :D
  19. 88B16ASiR
    88B16ASiR Light Weight Junkie
    mine i usually rev to about 2.8 and then 3.5 at 3rd and skip 4th
  20. BrutalB83
    Rochester Hills, MI
    You're right, yeah. My answer was somewhat over-simplified. Obviously the amount of throttle you're putting into it will have an effect on the amount of fuel you're burning. I was just saying as a general rule (and assuming that you're not constantly flooring it) the lower you shift the more gas you'll conserve...
