When to hit the juice
Discussion in 'Racing and Driving Techniques' started by reikoshea, May 15, 2005.
Thread Status:
Not open for further replies.
  1. reikoshea
    Dallas, TX
    I remember watching fast and the furious (strange way to start) and the dude said "too early". I take it that there is a specific time that is best to hit the NoS to get the best results. What is the best time to hit it?
  2. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    depends on you hit it the whole way if you want
  3. CRX-YEM
    Wallingford, CT
    usually at full throttle. But it really depends on what type of setup you have.
  4. allbottledup
    allbottledup Senior Member
    Galloway, NJ
    try as soon as you shift into second till you finish the run
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    i like to start at second or whenever they start catching up.
  6. reikoshea
    Dallas, TX
    Well i was thinking about running a 75 shot dry on my lude...if i were to do it, could i just set it up through a toggle switch and then cut it off when im done with my run?
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    as long as you have 2 of the big bottles you'll be ok :lol:
  8. reikoshea
    Dallas, TX
    lol well i have a friend thats a dentist who said he could hook me up with the bottles when i get it.
  9. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    that was kind of a joke. but i guess it would be helpful to have a larger bottle if you can't refill it half way through the night.
    Nitrous can be run in many different setups,
    anything from push button when you need it, i.e. passing on the highway.
    or in some drag racing setups multistage nitrous is used. so much when in full throttle automatically to keep consistancy plus a push button. like 50 shot and 100 shot or what ev.
    if you have the resources you will go faster holding the button down the length of the track. a toggle switch would work but you might go through it more.
  10. reikoshea
    Dallas, TX
    such is life...i did the math on it and there is going to be a lil over 3 grand without the mahle pistons and the turbo charger
    Between valve springs, fuel rail, fuel injectors, fuel pump, cam shaft, Zex dry nitrous, cold air intake (until i save the money for the turbo and new pistons) and headers (still have the stock cause i JUST did the swap into my lude) Gimmie about a month and ill have all that stuff setup.
  11. sohcslammer
    sohcslammer Senior Member
    Bay Area
    #1 You must sleeve an H22 to run forged pistons.
    #2 Why do you have only 1 camshaft in your H22?
    #3 Where does the 2nd header go on your 4 cylinder?
    #4 You sound like the perfect candidate for NITROUS.
    :thumbsup: Have Fun!!!!
  12. K2e2vin
    Raleigh, NC
    i dont think you need a fuel rail; ive heard of people using stock rails to around 400hp.
  13. reikoshea
    Dallas, TX
    #1 Mahle pistons are made to run on the H22 without resleeving it
    #2 I dunno why i said shaft instead of shafts
    #3 Ive always called headers headers even if there is only one.
    #4 is that sarcasm....cant really tell
    #5 Totally forgot i made this thread...sorry it took so long for the reply.
  14. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    LOL
    That'll be all...
  15. driver1
    driver1 Senior Member
    are you emplying u must run forged pistons in an h22 in order to run nitrous oxide?
  16. sohcslammer
    Bay Area
    No, he said he was running forged pistons. I have never heard of a piston that you can run in the H22 without sleeving it, (edit - I mean forged) henceforth I stated that he would have to sleeve the block, TRYING to help out and prepare him for the cost. So there.
  17. phunky.buddha
    Dallas / Fort Worth, TX
    Forged pistons for stock sleeve H22s have been out for quite a while... I just have no idea if they actually work or not. Some people say they don't.
    About 3-4 beers in to the night, or 10 if she's really ugly. :p
  18. driver1
    LMAO!!!!
  19. CiViC_SOHC
    CiViC_SOHC Senior Member
    wow thats funny shit :lol: but anyways why are you getting a DRY system those burn up shit easier then the WET systems I would more likely get a wet system therefore you have less problems about blowing a head gasket and such..
  20. formby
    formby learning in progress
Thread Status:
