where can i find this mount
haloae
im putting a b18c in my crx and the drives side mount i got for the swap has two bolts and they are at an angle(see pic) but my motor has the mount from the newer teg with 3 bolts in a triangle type pattern. i tried just using the stock teg mount but the motor sits up just a tad and the bolt hole is of by about 1/4" off. my question is does the older perludes with the b20s have the mount that bolts to the motor i need cuz there is one at a local junkyard and i can get it for cheap...if not does anyone have one or know where i can get one
you need the mount that bolts to the engine from 90-93 Integra B18
quote from Hasport instructions:
"This kit is designed to bolt in the 1st generation B-series engines into the 88-91 Civic or CRX. Make sure your B-series engine has the left-hand engine bracket from the 90-93 Acura Integra or first generation B-16A. If you need one it can be ordered from Hasport part no. EFLB or Acura part no. 11910-PR3-010."
