where has the oil gone?
Discussion in 'Engine Building' started by Taco15, Jul 26, 2006.
  1. Taco15
    Tallahassee Fl
    ok as some may now i just rebuilt my lsvtec with all new parts. I broke it in and the break in oil was fine. everything was going smooth. lately my car has been using oil like mad. within 2 weeks use 1/2 quart! what the hell? i dont leak it either. I smoke alittle when i get on it. nothing major. After a while though my bumper gets black if i let it.
    what could it be? i've wanting a catch can since i dont have one. My black box behind the block doesnt have any hoses either. its just there. isnt there supposed to be a hose from the intake manni to the box? All the seals are new including valve seals since the previous one smokes during vtec. also When i did a pass with some buddies they said that i was running rich.said it was a strong fuel smell when i passed by them. but i got the damn car tuned! i should be in the 14.xx A/F range
    help! the car is going in tomm to get a compression check,type R oil pump. pretty much try to figure out whats wrong
  2. TurboMirage
    check your drain plug.
  3. Taco15
    Tallahassee Fl
    for what? leaks? dude the car has sat inmy driveway for days at a time and never leaked not one single drop. Its really weird and scary. i dont see oil in the coolant. Every once in a while i'll see a pice or two of the gasket copper sealer. thats it.
  4. TurboMirage
    yeah, my new mirage doesnt leak either but the oil comes out of there. its just a hair wet right under the drain plug threads. i lost almost 2qts of oil ad i never left any spots.
    i changed the oil and put my fram quickchange plug in, almost ready for its next oil change and still proper level.
  5. Taco15
    Tallahassee Fl
    hmm thanks. i do have a little wet oily spot around the plug. under the distributer as well (ls dizzy with one bolt). thanks man i'll change that today and see what happens.
  6. Taco15
    Tallahassee Fl
    well i change the drain plug with a magnetic one and new washer. checked my canister in the back of the block and its hooked up right. the dizzy is the only thing thats got oil problems. I'll change that when i get a b16 one.
