Where Is The Best Place To Get Arp?
saturn_boy96
88 C1V1C 53D4N DR1V3R
Should i go ahead and buy ARP rod bolts along with the head studs? i am rebuilding my engine and would like to put it on boost once the build is over. this engine is not going to see any more than 250 whp, unless i think it can handle it. i need to know if the bolts are worth the upgrade, not because i am cheap but i just want to know if they really make a difference.
Also summitt has the rod bolts for like $35 bucks and the head stud kit for like $110. does anybody know of a better place to get this stuff?
thanks
Yup, it's worth the price. The stock bolts will cause the head to lift under boost and high compression NA applications. If you want to try a lower price, try calling Intercrew (number in sig). They might be able to beat your price...
