Where is the ECU ground for p72??
Discussion in 'ECU's, Electronics, and Tuning' started by 4drteg54321, Apr 28, 2009.
  1. 4drteg54321
    4drteg54321 New Member
    I have a apexi turbo timer and i want it to read my A/F it tell me i need to ground it to the Ecu Ground to correctly read it. But i have no idea where the ecu ground is. Where is the ECU Ground for a p72??
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the grounds for the ECU, Main Relay and the distributor wiring shields are all connected together at the ground wire from the engine harness that bolts to the thermostat housing - the actual ground locations at the ECU are at pins A23 and A24
  3. BrutalB83
    Rochester Hills, MI
    Get. Your. Car. Tuned.
    Yes, I read your other thread...
  4. 4drteg54321
    well i 1st tryed a23 but all it did was made the turbo timer flicker on and off
  5. 4drteg54321
    yeah that gonna be done once i get some more money
