where is the fill plug?
Discussion in 'General Tech and Maintenance' started by Ben, Nov 15, 2006.
  1. Ben
    Ben New Member
    for a b16 manual trans.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    right above the axle hole
  3. ONELIFEMOTORSPORTS
    ONELIFEMOTORSPORTS TURBO LAG=foreplay
    naptown
    WOW, i would look at a manual seriously!!!
  4. Ben
    Ben New Member
    i dont have the factory one, and my chilton doesnt say, and i have no money. so that is one reason why this forum exists... jerk.
  5. divisii
    divisii Member
    they're pretty easy to find, if you get under & look around ... near/above the drain plug/nut; it's a big nut on the side on the passenger side
  6. divisii
    divisii Member
    I found out my ex-mechanic filled mine full with motor oil ... bad. IMO only use honda trans oil
  7. get_nick
    Washington State
    motor oil isn't that bad. it's pretty common for hondas.
  8. divisii
    divisii Member
    Honestly that's what I thought too, get_nick. Even with my torqueless wonder .. I noticed shifter got very 'notchy' & then the bearings started makin noises it never made b4.
  9. get_nick
    Washington State
    my nissan is like that. if i don't use royal purple, it gets that way to. I have had 6 or 7 hondas, and a lot of the time they are notchy. for some reason they don't like to go into reverse when it's cold either.
  10. ONELIFEMOTORSPORTS
    naptown
    i did not mean to sound like a jerk, if that was applied to me heres a pic!!
  11. D See 2
    D See 2 Senior Member
    Baltimore, MD
    It's also pretty easy to fill from the VSS hole...
    D-Series 5 speeds take 1.9 qts
    B-Series 5 speeds take 2.1 qts
