projectxspeed
Can anyone give me an intelligent response to why you should not set your vtec crossover low?
lame post, don't waste space.
Originally posted by AppleSauseSi@Jun 6 2004, 02:31 AM
If you set the crossover high the engine will start to "suffocate" and lose efficiency, if you set it low the engine will have a smooth crossover and there wont be a beefy kick, it will eliminate the uncomfortable jump in the power band.
Mine needs to be lower for a smoother power curve, but I don't want to drive around all day in VTEC. 70mph = 4000rpm, and that's where I need my VTEC at- but that's also freeway cruising speed.
