Where To Buy B20b4 Block And B18c5 Head?
Hey..
Who knows a good place to get a B20B4 Block and a B18C5 head to put on it?
And then a T3/T4 turbo kit to run 12 psi of boost on it? (new rods, pistons, bolts, and sleeves of course)
Thanks!
Im in Minnesota....
and I changed from a b18c5 to a b18c1 .. or maybe a b16
Im going to swap the b20b4 into a 94 civic ex coupe, so Id like all the parts needed to do that
Im going to either put the b16 or b18c1 head on it, and then turbo it at 12ish psi to get 12's
I will resleeve it, new pistons, rods, and bolts are also going in.
Can a b16 head take that much power? or should I go with a b18c1?
Anyways... now you know what I want... just where can I get it for cheap.
i would say just get a built engine from importbuilders.com
you can get it all prebuilt for whatever you want to do with it ... it will most likely cost less than piecing it together and getting the work done after
IB makes some sick ass engines
and im pretty sure you can get the turbo setup from them too
