where to get these?!?!
Discussion in 'General Tech and Maintenance' started by INJEN78, Feb 6, 2008.
  1. INJEN78
    INJEN78 HS LEGEND
    OHIO
    where in the hell would i go to get bolts to put the tranny to the engine(bellhousing bolts) and the clutch to the flywheel.!??! like a dumbass i left them in the car that i junked
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    honda for the fly wheel, and autozone for the others
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    awesome..what do i say at autozone??
    uh yea im a fuckin moron,and uh i need the bolts for the bellhousing??
  4. AHHVTEC
    Alabama
    just your run of the mill auto parts thats why, any will do,, advance,,ect ect
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    The transmission bolts may be M14-sized bolts, or bigger.
  6. K2e2vin
    Raleigh, NC
    Also, I have some left-over from an Accord that should work. LMK if interested...and I can get pics tomorrow if needed.
  7. BrutalB83
    Rochester Hills, MI
    NAPA or Autozone will probably have what you need. Try looking it up on their site beforehand. Then you'll have part numbers when you go. I've been able to find pretty much any obscure bolt that I've ever needed at NAPA.
    And of course the dealership will have them. I'd check other places first though, the dealership will probably be a ripoff.
    Also, you could try checking out hondaautomotiveparts.com. I'm sure you could get the bolts you need there, and probably for cheaper than through a dealer.
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    parts stores will probably need to know lengths and sizes first though right??
    and that hondaautoparts place didnt work
  9. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
  10. BrutalB83
    Rochester Hills, MI
    Do you mean the link didn't work or you couldn't find the parts?
    The link works, maybe you didn't type it in right.
    Majestic Honda - The Internet's #1 Honda Automotive Parts Store
    And the stores won't necessarily need the sizes, they may be able to look them up, or you might be able to find them on the website first. Like I said, I found a bunch of bolts and random junk that I needed through NAPA.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok soo im just going to use the bolts from my d16.i know the ones for the housing will work but not too sure on the ones for the clutch
  12. K2e2vin
    Raleigh, NC
    The clutch bolts look to be the same as the D16; flywheel bolts should work too but you'll be sort like 2 bolts IIRC.
