Where to ground wire from Battery?
Discussion in 'General Tech and Maintenance' started by MarkJimenez99, Dec 22, 2003.
  1. MarkJimenez99
    MarkJimenez99 Senior Member
    Hey guys. I need your help. Where does the wire coming from the battery hook up to? The wire I'm talking about is covered with rubber. Where am I supposed to ground it? I just finished installing a clutch. Also, was I supposed to ground the chassis to the tranny? Just double checking. Thanks.
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    OEM has it so that it comes from the battery, to the chassis, to the transmission.
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    what you should do is have it:
    battery...tee-d off....to the chassis and tranny all with the same guage wires.
    Thats what i've heard is a good way to ground everything.
  4. MarkJimenez99
    What does "tee-d" mean? I just need to know where EXACTLY I need to ground that wire from the battery. I already grounded the chasis to the tranny.
  5. 92civicb18b1
    well to do it the oem way, theres a hole on the strut tower...it bolts down with a 10 mm bolt.
  6. MarkJimenez99
    Well, I think I did that the first time when I attempted to ground it to the chassis. When I tried to jumpstart the car, it was sparking and smoking. That tells me that I grounded something wrong and it was probably that wire from the battery. :(
  7. 92civicb18b1
    make sure no positive wires are touching the chassis check for any shorts.
