Where's the Air Intake Sensor on 2nd Gen B16A
Discussion in 'HYBRID -> ED-EF / DA' started by tdaddylove, Mar 15, 2004.
  1. tdaddylove
    tdaddylove Junior Member
    Okay everything is almost done. I figured out where the Water Temp sensor was. The car runs a lot better now and i only have one code throwing besides the vtec ones(i didnt' up vtec yet) and thats the IAT (intake air temp) code. I looked at a 1st gen b16a manual and it shows the sensor on the intake manifold near the injectors but its different on my motor. Anyone one know where this sensor is hiding?
    I also have a problem with the vtec knock sensor. The motor had the sensor capped off for some reason, and i dont' know which pin is supposed to run to the computer and which one is supposed to go to ground. I tried to get a reading with a Volt meter but i had no luck. Now that i think about it, its probably all current coming out of the knock sensor.
    I also had to used the map sensor on the throttle body and not the one on the firewall for some reason. I really should do a write up on this swap. ;)
    Thanks for all the help,
    Tim
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    I swapped to the ITR intake manifold and mine is on runner #1, just under the FPR.
    I want to say that the one on the B16a motor is there, or just underneath that area on the intake manifold.
  3. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    on 99-00 civic si's b16a2 it is in the intake piping.
