Wheres the Stock amp on 03 civic coupe
mrquiggles
I installed all 3 sets of speakers for my civic soldered and heat shrinked ;) But these speakers have way more power in them then the crummy stock speakers. I want to replace the stock amp so I can make sure I get the real deal out of my speakers, but I can't find it and I lost my manual. Can anyone help? thnx
if i remember right its up front under the center console in the center of the dash area
just use a line out put converter to get signal they will put out around 3 volts,, never messed with newer civics if you have after market deck just use speaker leads from factory side of the wire harness adapter,, not the deck side had to do that on my 01 impala with factory amp
