Which 1?
Discussion in 'HYBRID -> EG-EK / DC' started by RS1, Jan 10, 2003.
  1. RS1
    RS1 Junior Member
    Aight, im plannin on getting a new ride soon, and i dont know which ride to get out of these three choices,
    99-00 hatchback, w jdm b16 motor (92-95 del sol)
    99-00 civic si coupe
    97-00 Gsr
    which one would be easier/cheaper to break into 13's all motor...
    Thanks im a newb btw... :)
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    99/00 hatch.... the gsr wouldn't be bad either because you are starting with alot of base power.
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    dont put a b16aSIRii engine in a 99-00 hatch, instead get the b16a2 (if you want the b16) the SirII is obd1 and your car is obd2, the other way is not hard but
    obd2-obd1, not good,
    obd1-obd2, easy.
    Instead of puting the b16 in there, put the b18c, much better engine.
  4. RS1
    RS1 Junior Member
    ok lets say i get the hatch w/JDM B16A1, how much will it cost for everything except the install, the gsr is kinda too expensive for me right now
  5. prawjEKt Cx
    upstate NY
    no no no, no b16a1.... get either a sir-2 swap or a usdm b16a2.. sir2 swaps are going for around 2 grand right now.
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    where are they going for 2 grand??
  7. prawjEKt Cx
    upstate NY
    well $1850 w/out axles at osaka..... so i just figured 2000 after axles
