Which A/C compressor and A/C bracket for B20vtec
Discussion in 'General Tech and Maintenance' started by DanTheHondaMan, Dec 3, 2016.
  1. DanTheHondaMan
    DanTheHondaMan Active Member
    I want to retain A/C in my car. I live in Florida and it gets well over 102 degrees during the summers so I would like to keep.
    As the title reads.
    Which A/C compressor and A/C bracket should I use for my B20vtec and this in in my 2000 civic ek
    I tried searching and couldn't find an answer.
    thanks
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Same AC mount as for the 99/00 Civic Si B16A2 (EK chassis)
    DanTheHondaMan likes this.
  3. DanTheHondaMan
    Awesome thanks man. I really appreciate it. I've been searching an searching and couldn't find the answer.
    Does it matter which compressor I use?
    Should I use an a/c compressor from a 2000 civic Si as well?
    also couple more questions.
    Which belt for which car should I use and what size if you know?
    and last but not least what would I have to do in order to retain power steering? Not a huge issue but would be nice to have it if its not too complicated.
    Also would you happen to have the part numbers by chance?
    Thanks for the help
  4. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Iirc any obd 1 or 2 ac compressor are the same
  5. CAFROG
    NOR-CAL
    Some are R12. But all EK are all R134A. Any EK compressor will work.
    I'm guessing the 99/00 Si belt will fit but (if not) you can measure with a string and get a belt long enough with enough ribs.
  6. DanTheHondaMan
    Thanks for the help CAFROG
