Which alternator belt with CTR n1 crankpulley
tnsxsear
Whic belt do I use since the old alternator belt wont work with the CTR crank pulley?? thanx
You can also just use a length of string. Wrap the string around the pulleys and then measure the string...Shade-tree...I know...but it works!
yes,thats probably easier if you arent like me and have to make 300+ runs there anyway,either way the parts store will get you a belt that will fit
your are correct in terms of having to use a different belt, not sure which one though.
I believe E knows off hand - so you can PM him if you want.
great mod though :thumbsup:
