Which B16 for an EG
Dude, all this crap is in the swap guide/reference section.
BUT... if you're just too lazy, you'll want to stay OBD I so go for a B16A3 from a Del Sol VTEC or a JDM B16A SiR II. It's a good idea to just get the whole changeover if you're starting the project from scratch. Plus, there is no better place to buy from than Hmotorsonline.com.
Also, you'll want a hydraulic tranny.
i have a 94 vx and i got the b16a sir2 swap....im going to state ref. and in order to get it approved i have to make it look like a del sol...
depends on the chassis. ex/si, cake, all the rest require minor mods- all of which is covered in the tech articles
Not fi it's a JDM harness, they are backwards. But the ECU will plug right in.
[post=555968]Quoted post[/post]​
the jdm harness is backwards from the jdm ecu?
[post=556028]Quoted post[/post]​
He means that because the JDM engine came out of a JDM right hand drive car, the ECU is on the other side, so the harness is exactly opposite the USDM one. ;)
Originally posted by scottp11+Sep 17 2005, 08:15 PM-->
Originally posted by Silver_Surfer@Sep 17 2005, 07:08 PM
92b16vx
[post=556029]Quoted post[/post]​
i sort of figured that. Does that make it hard to reach?
What??? Dude, use your stock harness... Modify it by using the harness off the JDM engine and cut/solder the correct plugs onto your stock harness.
