Which Cam Gears Are The Best?
Discussion in 'Engine Building' started by NoJokE, Feb 17, 2003.
  1. NoJokE
    NoJokE Senior Member
    Im torn between the AEM cam gears and the Spoon, which are better? Any other cam gears that provide the best result, $$$ not an issue.
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    anything other than aem
    aem have only 3 bolts and could slip.
  3. E_SolSi
    :werd: dont bother wasting your time or money on the AEM's
  4. Havok
    Havok Senior Member
    Florida
    1st off, for what application? if it's B series, you got more (better) options.
  5. chet
    chet Senior Member
    st petersburg, florida
    here's my experience with cam gears...
    spoon/toda are badass...as you get what you pay for!
    now, skunk2 gears work well, although under extreme conditions the gears can sometimes expand, causing the timing belt to become tighter and this can cause a motor to seize, bad!!!!!!!!!!
    but this is in rare conditions, and unlikely to happen, although i'd check the tension of your timing belt from time to time...
    aem gears...yes i worry about them slipping, however when torqued correctly they can be reliable...
    for a daily driven setup i'd go with skunk2 gears. personally, i'm going with toda cam gears when i have the money, of course there are others out there including endyn and str which are also supposed to be good. i can't comment on these, because i've never used them.
  6. pissedoffsol
    toda B) B) B) B) B)
    skunk2 B) B) B) B)
    aem :eek:
  7. Holy_racer
    Holy_racer Member
    What kind of motor do you have?
    Any kind of motor i still recommend you to get JG cam gear.
    They have the best cam gear. That shit put hard!!!
  8. civicSiR1
    civicSiR1 Senior Member
    I highly recommend Toda's....it's so simple to adjust and gives you the right output on how you want your cams to run.
  9. gtpilot
    gtpilot Member
  10. Darivative
    Darivative Guest
  11. pissedoffsol
  12. chris
    chris Senior Member
    nihon
    just another factor, u want ones that utilize or have the same "teeth" as the OEM cam gear.
    Toda works for me btw
  13. 2fastaccord
    2fastaccord Senior Member
    Go with Skunk2 that don't cost you nearly as much as spoon and they have 6 bolts. I have one on my car and would highly recommend it.
    Peace*
  14. E_SolSi
    the only issue with the skunk2s is that the bolt heads can strip if your not careful .... you shouldnt really be fucking with them all the time any way though ... just get it tuned ... set em and forget em... or replace the bolts with better ones
  15. civicSiR1
    Darivative---> yeap, them Jun works very well, i had a pair until i rebuilt my head and replaced it with todas....
  16. NoJokE
    I got a B18CR, i dont care for price, which is the absolute best? JUN, Spoon, Toda, Skunk2?
  17. E_SolSi
  18. civicSiR1
    don't care for price eh.....TODA!......if you want some power too, get the spec c shafts.....very simple to adjust.....on move it right to retard, and left to advance.....
  19. Havok
    Havok Senior Member
    Florida
    :withstupid:
