So which aftermarket cams do you guys have? The reason im asking is that i purchased the skunk2 stage1 cams and one day later I floated a valve and bye bye motor. I had a b16 swap. Now I noticed that all the cam guides said that stock valvetrain would be fine with the stage 1s. I even called skunk 2 and they said stock valvetrain would be fine. So I was just curious if you guys have run into any situation like this or if you have those cams in your motor now without any problems?
