Which cat converter?
Discussion in 'HYBRID -> EG-EK / DC' started by Slammed90Lude, Jun 3, 2004.
  1. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    ok, in case you don't know I swapped a 95 JDM gsr motor into my 92 civic hatch- I've got everything else figured out except this- What cat converter do i use with the swap? i'm running the stock exhaust manifold, and my o2 sensor is in the header ( not in the cat like I expected)
    does anyone know of a directly fit cat for this setup (i'm running the RSR GT-Mag catback) or else is there a place where i can buy a universal cat and the correct flanges that i need for it to fit (yes I can weld)
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Just get a powercore, or Car Sound from Ebay, and if need be, do what I did and cut out a half inch or so. I can never remember the exact fitting one for a GSR header on an EG.
  3. highperboi
    highperboi Senior Member
    Alameda, California
    doesnt your o2 wire reach the cat?? the gsr harnesss should. if not extend it and get a gsr cat. i am using a gsr cat but i am also using at gsr exhaust.
  4. BodyDroppedNikes
    caught in a mosh...
    i got my Magnaflow high flow catalytic converter off of eBay for $58.50 brand new.
  5. Slammed90Lude
    milford, PA
    well a 94 ls cat doesn't work
    why would i want to extend the wires of my o2 sensor to reach the cat? the sensor is already in the downpipe of the header and is already reading gas from all four cylinders
    i'm gonna go over to landspeedracing.com right now and see how much i can get one for- for the record though, it needs to be 16.5 inches long in case anyone is wondering
  6. Slammed90Lude
    milford, PA
    a stock civic cat doesn't work either, i'm gonna order one for a GSR tonight and pray that it works
  7. vpSPOONsol
    vpSPOONsol Senior Member
    mildenhall village, england
    the magna flow one on ebay's 16.5" while the catco ones's 14.5"...and they have all the diameters you need
  8. Slammed90Lude
    milford, PA
  9. sleepercivic
    sleepercivic Senior Member
    NC Mountains
    if you get an after market header, get one for the type r and it should bolt up to the stock cat, as long as it is not a JDM header
