which clutch with a b16a
Discussion in 'HYBRID -> EG-EK / DC' started by crxracing77, Oct 29, 2002.
  1. crxracing77
    crxracing77 Senior Member
    west lafayette in or clw florida
    I was wondering which clutch and pressure plate i should use when i do my swap and how much it will cost?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If you use Honda, get the ITR setup. If not then Clutchmasters is good. While you are in there get an aluminum flywheel, it is worth the money ans easier to do when you are already changing the clutch.
  3. crxracing77
    well my budget for isnt going to be enough for the fly wheel to. so ill have to do it later on... but clutchmaster? what abt act/.... price and quality compare?
  4. lsvtec
    Clutchmasters is the only company that I have never heard anyone bitch about quality. I know many people running a CM clutch and none of them are dissapointed. I opted for the ITR setup but only because I was already buying $700 of parts for my LSVTEC that I got a hell of a deal on it.
  5. crxracing77
    oh ok ...i know of topic, but i found a deal for mounts and shiftlinkage and axles for 450... is that bad...
  6. lsvtec
    I couldn't tell you on that one.
  7. crxracing77
  8. pissedoffsol
    450 for all 3 is a great price
    and i'd also rec the CM stage3
  9. E_SolSi
    i would recomend ACT... ive seen clutch masters get blown apart in 500 miles ... ive also heard some good about them ... they dont seem too consistant ... only heard good stuff about ACT
  10. crxracing77
    how much does a stage 3 cmcost ?
  11. lsvtec
    I heard heard exactly that only reverse the brands (so they had their ACT blow up before it was broken in). I guess it depends on who you talk to. My ITR clutch is holding up great. If you are staying NA, you can't go wrong with Honda parts. :)
  12. Baker
    Baker Senior Member
    Schaumburg, IL
    heres the deal, clutchmaster builds their own clutches, ACT are reworked clutches. The founder of ACT actually worked at clutchmaster before starting his company. I just put a stage 4 clutchmaster in when I did my swap. Really stage three is all thats needed but the stage four is rated to put down about 14% more power. I really like it aside from the studder starts but if you go with stage 3 you won't run into this problem
  13. crxracing77
    stage 3 a 4 four puck
  14. lsvtec
    For street driving (I don't know if the Stage 3 or 4 is made of a ceramic) stay away from the ceramic material unless you need it. It eats flywheels bad. Kevlar or Organic is the way to go for street use.
  15. knowledge
    knowledge Senior Member
    Beale AFB, CA
    The CM stage 3 is a carbon/kevlar and it isn't a 4 puck! The CM stage 4 is a 4 puck!
  16. crxracing77
    what is the advantage of a 4 puck... and how muc hthey run ?
  17. knowledge
    Beale AFB, CA
    4 puck will be more expensive! With the 4 puck you will need some serious mods to take full advantage of it! Also the 4 pucks aren't very streetable!
  18. crxracing77
    so like a stage 2 or 3
  19. D See 2
    D See 2 Senior Member
    Baltimore, MD
    yea... stage 3 is 6 puck and thats the most aggressive i would use for streetability... 4 puck is geared toward the track whereas the 6 puck is for both. :) however if your going for just a track car... hell, go with the 4 puck.
  20. crxracing77
    ill stick with the stage 2 or 3
