which distributer on mini me?
Discussion in 'Engine Building' started by CRX2NR18, Apr 3, 2004.
  1. CRX2NR18
    CRX2NR18 Senior Member
    well today i pulled out my crappy HF motor sense i wont be driving my car for the next month anyways. So i started the buildup of my mini me, got the block assembeled with new bearings and piston rings. head is all done and all that, problem is my HF dist. wont fit in the EX head... is this common? which dist. will i have to use? i mean i dont want to rewire the car so it will have to be an HF or SI, do i have to pull the head apart to fit the distributer in there and put it all back togeher? only 1 of the 3 holes lined up, thanks for your help
    TJ
  2. E_SolSi
    you need the distributor for the head you are using
    people have hacked it together just using the one hole that lines up .... i wouldnt recomend it though
  3. CRX2NR18
    if i used the z6 dist. woudlnt i have to rewire some of the car cuz of the HF dist is different
  4. lsvteccrx
    lsvteccrx Senior Member
    new york
    did your HF have DP injection or MP injection originaly?
  5. lsvteccrx
    new york
    Ive done this before. you can only use 1 bolt correctly but if you either extend the slot closest to the front of the car or grind it down, you'll be able to get that bolt to hold it also
  6. lsvteccrx
    new york
    that was for the HF dist.
  7. Jeef
    Jeef NO MA'AM Moderator VIP
    Use the distribtuor for the the obd you are running. Like the guy above me said you will have to grind your dist a little to get it to fit. I think when I did it I only used two bolts to hold the dist in. Make sure you check the timing.
  8. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :withstupid: and make sure those bolts are good and snug
  9. CRX2NR18
    how do i get the distributer to fit into the head, like it didnt seeem to want to goat all, is there like a lock on it that makes it snap in? or what cuz it was pissin me off lol
  10. HondaMoCo
    HondaMoCo Senior Member
    lancaster/palmdale So Cal
    get a dremel or a hack saw and cut all the arms off of the HF/SI distributer just where the slot is, then take 3 large washers and the three distributer bolts and the washers will clamp down the distributer, i have to do this everytime i put a d15b vtec in a EF, it hold perfectly . As far as the distributer not fitting in the head, it fits, but the little key piece that goes in the cam is not asemetric, the two little lines are off center so if you are having a problem putting it in, turn it 180 degrees and then try abain
