which ecu for Zdyne
BoogieDown
i have a Std/dx PM5 ecu and zdyne says they can't use it since its dual point and my friend will sell me is HF ecu PM8 for 50$ can i use a CRX ecu? there both obd 0 so the connectors should be the same right? but the way you get the codes are diffrent
I would call zdyne and ask them sicne they are going to be doing the work. But the hf ecu is for mpfi but it has an egr valve in it and the other civic from that generation did not have one.
its for a B16.they have the one wire vtec setup.
i have never heard anything bad about them. and i called and said it will work fine
