which ecu or d15b jdm vtec??
micmac
Bought a jdm d15b vtec engine to replace my p4 civics non vtec stock. What ecu will I need for the new engine? Is there anything else I will need for this swap also?
94 civic 4dr 5spd lx
P08 is stock for that engine, but you'll need to run a one wire o2 sensor... If you use a P28, P30 or the like you'll need the 4 wire o2... P08s are dirt cheap and readily available... P28s are second behind that, decent price and pretty easy to find... Good luck man... Let me know if you need info on where to purchase these...
I've been looking on ebay, but I'd rather buy them from someone I can trust. Where is the best place to find the ecu I will need as well as help me with the wiring for the o2 ??
