Which engine do you guys prefer to turbo LS or gsr
Discussion in 'Forced Induction' started by japspec01, Apr 5, 2004.
  1. japspec01
    japspec01 Junior Member
    I just wanted to get a better understanding on which engine you guys think would be a better choice to turbo. I can understand why a high compression engine block would benefit from a vtec head. from what I learned the smaller cam lobes allow the engine to idle better,burn less fuel, and increase low end tourqe. The bigger cam lobes allow for all that 12.5:1 compression to get into the combustion chamber making it a fun ride. I'm yet to understand why alot of people want to turbo their gsr engines. Wouldn't it be better to turbo a ls?
  2. CRX2NR18
    CRX2NR18 Senior Member
    LS in my opinion, be like cheesefrog :D
  3. NotUrAverage_Si
    NotUrAverage_Si Senior Member
  4. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    At 10psi or less, with good fuel tuning, GSR internals are fine. Even with 10:1 compression. Plus, the GSR cams are perfect for boost. VTEC + boost is fun because not only you get the extra charge from the turbo, but the big lobes flow that extra air 10000000000000 times better. Plus, the LS head can't flow for shit from the factory.
  5. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
    :werd:
    and on that note of 10 psi, looky look here and here*
    good luck making that power with stock bottom end and LS cams running 10 psi.
    * only at 9:1 CR too :)
  6. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    :werd:
    -a comparable setup on an LS and GSR will always make more power on the GSR with the same tuning
  7. pissedoffsol
  8. jaydemdc2
    jaydemdc2 Member
    seattle wa
    :werd: the GSR for sure!!!
    what ever happend to a search?
  9. mwvnos
    mwvnos Senior Member
    SC
    geez, lets beat a dead horse one more time.....do a search man..
  10. dvus1
    dvus1 Senior Member
    somewhere in GUAM
    :sleep: ohh is it over......
  11. Import Builders
    Import Builders Senior Member
    LA, California
    We did 2 similar motors. 1 LS, the other one GSR.
    The LS made 260 WHP with alot of torque at 10 PSI, and the GSR did 322 WHP with a little less torque at 10 PSI.
    Thats 62 WHP from VTEC.
    Jeff
  12. japspec01
    Thanks import builder for bring this topic back. What compression did the ls and gsr engine have?
  13. Import Builders
    LA, California
    They both were 9:1 or close to it.
    Jeff
