bdogggut34
I'm eventually gonna build an LS/vtec within a year or so. What would be cheaper in the end getting the full LS swap and buying the head or the full B16 SirII swap and buying the block?
Originally posted by Calesta@Jul 6 2004, 11:29 AM
You do NOT need a Hondata to run an LS/VTEC engine. You can swap ECUs and run a few extra wires for VTEC later with the B18, or you can control VTEC and your fuel maps with a VAFC or some other piggy-back system.
Originally posted by twisted civic+Jul 6 2004, 01:36 PM-->Calesta@Jul 6 2004, 11:29 AM
wouldn't it be cheaper to use a hondata setup?
Originally posted by bdogggut34@Jul 6 2004, 03:18 PM
if i was to build the block up a little bit do you think it would be best just to get an LS block at a junk yard whether it has high miles or not? I figured since its a buildup it wouldnt matter
